- Primesolve (PP:12)
- RISC OS FR : The Raspberry Pie contest (News:23)
- South West Show is fast approaching (News:)
- RISC OS interview with Richard Keefe (News:1)
- ArtWorks 2.X3 released (News:3)
- December News round-up (News:)
- RISC OS interview with Rob Coleman (News:1)
- 10 RISC OS gift ideas for Christmas (News:)
- Drag'N'Drop Autumn edition now available (News:)
Choice of algorithm
Implementation
Figure 1
Figure 2
Initial problems
Figure 3
Road weighting
Implementation details
typedef struct _road_path {
  int l;
  struct _road_path *next;
  corner *c;
  struct _road_path *lnext;
} road_path;
Tweaking and improvements
Figure 4
Figure 5
