- Example output from *ROMModules
- Example output from *ImageFileConverters
- Example output from *ImageFileRenderers
- Current state of the boot sequence and harddisc build
- Early August Update
- Wakefield 2001 show report
- Wakefield 2002 show report
The Icon Bar: News and features: Example output from *ShowStat
Posted by RISCOS Ltd on 00:00, 7/5/2003 | , , ,
ShowStat 1.10 (29 Mar 2002): DCI4 statistics gatherer
© ANT Ltd 1999, RISCOS Ltd 2001
Device Driver Information Block
Unit : 0
Address : 00:C0:32:00:88:84
Module : EtherH
Feature flags :
: Multicast reception is supported
: Promiscuous reception is supported
: Interface can receive erroneous packets
: Interface has a hardware address
: Driver can alter interface's hardware address
: Driver supplies standard statistics
Interface type : 10Base2 ethernet
Link Status : Interface okay
Active Status : Interface active
Receive mode : Direct, broadcast and multicast frames
Duplex mode : Full duplex
Polarity : Incorrect
Bytes transmitted : 176
Last TX address :
Received bytes : 119
Last RX address :
Module 'MbufManager' is a supplier titled 'Mbuf Manager'
Mbuf Manager : System wide memory buffer (mbuf) memory management
Active sessions : 4
Sessions opened : 5
Sessions closed : 1
Memory pool size : 262144
Small block size : 128
Large block size : 1536
Mbuf exhaustions : 0
Small mbufs in use : 2
Small mbufs free : 510
Large mbufs in use : 0
Large mbufs free : 128
Module 'ZeroConf' is a supplier titled 'ZeroConf client'
ZeroConf client : Zero-configuration IP address management
Interface : eh0:9
State : Configured
State change : 19:21:03 05-May-2003
Our address : 169.254.91.113
Address change : 19:20:59 05-May-2003
Total collisions : 0
Module 'AppleTalk' is a supplier titled 'AppleTalk Protocol Stack'
AppleTalk Protocol S: AARP, DDP, ZIP, RTMP, NBP, AEP, ATP, PAP, ASP, DSI, AFP
AARP ext lookups : 0
AARP int lookups : 0
AARP int hits : 0
DDP out requests : 5
DDP in datagrams : 0
DDP no prot. handler: 0
DDP too short error : 0
DDP too long error : 0
DDP checksum error : 0
RTMP version mismatc: 0
RTMP in error : 0
ZIP GetNetInfo : 1
ZIP GetNetInfo repli: 0
ZIP zone invalids : 0
NBP in lookups : 0
NBP in replies : 0
NBP out lookups : 0
NBP out replies : 0
AEP in requests : 0
ATP in packets : 0
ATP out packets : 0
ATP request retries : 0
ATP responce retries: 0
ATP release lost : 0
PAP open connection : 0
PAP in data : 0
PAP out data : 0
PAP in close connect: 0
PAP out close connec: 0
ASP in transactions : 0
ASP out transactions: 0
ASP in open sessions: 0
ASP out open session: 0
ASP in close session: 0
ASP out close sessio: 0
DSI in commands : 0
DSI out commands : 0
DSI in open streams : 0
DSI out open streams: 0
DSI in close streams: 0
DSI out close stream: 0
Mbuf failures : 0
Module 'DHCPClient' is a supplier titled 'DHCP client'
DHCP client : Dynamic interface 0
Interface : eh0
State : BOUND
Our address : 192.168.0.201
Server address : 192.168.0.100
Relay addess : No address
Lease period : 30 mins
T1 period : 15 mins
T2 period : 26 mins, 15 secs
DHCP started : 19:20:47 05-May-2003
Lease started : 19:20:51 05-May-2003
Lease ends : 19:50:51 05-May-2003
T1 end : 19:35:51 05-May-2003
T2 end : 19:47:06 05-May-2003
