Simon Wilson of
PCITV fame has just released the first version of
IyonixMesa, a code library that will allow programmers to make use of the 2D and 3D graphics acceleration supported by the nVidia GeForce 2 MX card that is used in every
IYONIX machine. The work is based around
Rudolf Cornelissen's 3D acceleration driver for BeOS and the
Mesa 3D API. The library is suitable for use with C programs written for
RISC OS GCC, and best of all it's available free of charge.
3D acceleration for RISC OS. No, really! |
(18:11 2/9/2005) Guest (11:53 3/9/2005) Jeffrey Lee (14:34 4/9/2005) Jeffrey Lee (14:34 4/9/2005) Guest (07:27 17/9/2005)
Jeffrey Lee |
Message #87762, posted at 18:11, 2/9/2005 |
Unregistered user
Note that I am currently accepting donations for the "Get Phlamethrower an IYONIX" fund. Send your money now and get your favourite open-source 3D game ported free of charge! ;) |
Guest |
Message #87763, posted at 11:53, 3/9/2005, in reply to message #87762 |
Unregistered user
I was going to say what are the possibilities now games-wise?
AW |
Jeffrey Lee |
Message #87764, posted at 14:34, 4/9/2005, in reply to message #87763 |
Unregistered user
I'd say that most open-source OpenGL games up to around 1998 could be ported. Anything beyond that would probably require too much maths for a machine that doesn't have hardware floating point support. Depending on whether the driver supports hardware T&L, things may be better/worse than that estimate. |
Jeffrey Lee |
Message #87765, posted at 14:34, 4/9/2005, in reply to message #87764 |
Unregistered user
Of course Simon will probably be able to give a better answer :) |
Guest |
Message #87766, posted at 07:27, 17/9/2005, in reply to message #87765 |
Unregistered user
Yep, hardware texture and lighting is supported. The fillrate is phenomenal (looks as good as a PC), but the trirate needs improvement. Not all the pipelines in the GPU are used at the moment, even in the BeOS driver, in particular anything to do with transformations. A fixed point driver, which is in the works, would allow much newer 3D games to run just fine with suitable modifications. Not talking Half Life 2 here, but perhaps the Quake III engine. -Simon |
